TwinTurbo.NET: Nissan 300ZX forum - TPS is just a variable resistor - they can go bad over time.
jzack
on August 22, 2013 at 11:54 PM
Re: Anyone know what I'm doing wrong?
posted by blackice98
on August 22, 2013 at 10:30 PM
That would cause voltage jumps instead of a smooth linear voltage ramp. Main issue - sweep arm of the variable resistor isn't making good contact...
iamdan012
19:06:37 08/22/13
Very possible the TPS could be reading bad, just move slow (n/m)
Zinister1
20:41:39 08/22/13
Do you have a really solid ground connection? Has to
jzack
21:13:17 08/22/13
blackice98
22:30:41 08/22/13
TPS is just a variable resistor - they can go bad over time. -
jzack
23:54:09 08/22/13
just in case you are doing it wrong have a look here:
Medallion Man
01:50:31 08/23/13
You can't ohm a Circuit with power on it..
Cjw3
13:19:29 08/23/13
